Cesium for Unity 1.26.1
CesiumForUnity.ICesiumRestartable Interface Reference
An interface for an object with a Restart method, allowing the state of the object to be reinitialized from its serialized properties. More...
Inheritance diagram for CesiumForUnity.ICesiumRestartable:
CesiumForUnity.CesiumGlobeAnchor
void Restart ()
 Completely re-initializes the state of this object from its serialized properties.
Definition at line 7 of file ICesiumRestartable.cs.
◆ Restart()
void CesiumForUnity.ICesiumRestartable.Restart ( )
It is not usually necessary to call directly. It can sometimes be useful after Unity has modified the private, serializable fields of this instance. For example: after an undo or redo operation.
Implemented in CesiumForUnity.CesiumGlobeAnchor.
The documentation for this interface was generated from the following file:
