Cesium for Unity 1.26.1
CesiumForUnity.CesiumWebMapTileServiceRasterOverlay Class Reference
A raster overlay that directly accesses a Web Map Tile Service (WMTS) server. More...
Inheritance diagram for CesiumForUnity.CesiumWebMapTileServiceRasterOverlay:
Protected Member Functions
Properties
string baseUrl [get, set]
 The base URL of the Web Map Tile Service (WMTS).
string layer [get, set]
 The layer name to use for WMTS requests.
string style [get, set]
 The style name to use for WMTS requests.
string format [get, set]
 The MIME type for images to retrieve from the server.
string tileMatrixSetID [get, set]
 The identifier of the TileMatrixSet to use for WMTS requests.
string tileMatrixSetLabelPrefix [get, set]
 The prefix to use for the tile matrix set labels.
bool specifyTileMatrixSetLabels [get, set]
 Set this to true to manually specify the tile matrix set labels.
List< string > tileMatrixSetLabels [get, set]
 The manually specified tile matrix set labels.
CesiumWebMapTileServiceRasterOverlayProjection projection [get, set]
 The type of projection used to project the WMTS imagery onto the globe.
bool specifyTilingScheme [get, set]
 Set this to true to specify the quadtree tiling scheme according to the specified projection, root tile numbers, and bounding rectangle.
int rootTilesX [get, set]
 The number of tiles corresponding to TileCol, also known as TileMatrixWidth.
int rootTilesY [get, set]
 The number of tiles corresponding to TileRow, also known as TileMatrixHeight.
double rectangleWest [get, set]
 The west boundary of the bounding rectangle used for the quadtree tiling scheme.
double rectangleSouth [get, set]
 The south boundary of the bounding rectangle used for the quadtree tiling scheme.
double rectangleEast [get, set]
 The east boundary of the bounding rectangle used for the quadtree tiling scheme.
double rectangleNorth [get, set]
 The north boundary of the bounding rectangle used for the quadtree tiling scheme.
bool specifyZoomLevels [get, set]
 Set this to true to directly specify the minimum and maximum zoom levels available from the server.
int minimumLevel [get, set]
 The minimum level-of-detail supported by the imagery provider.
int maximumLevel [get, set]
 The maximum level-of-detail supported by the imagery provider.
int tileWidth [get, set]
 The pixel width of the image tiles.
int tileHeight [get, set]
 The pixel height of the image tiles.
string materialKey [get, set]
Additional Inherited Members
void AddToTileset ()
void RemoveFromTileset ()
void Refresh ()
https://www.ogc.org/standards/wmts
Definition at line 33 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ AddToTileset()
override partial void CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.AddToTileset ( Cesium3DTileset tileset)
protected
◆ RemoveFromTileset()
override partial void CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.RemoveFromTileset ( Cesium3DTileset tileset)
protected
Property Documentation
◆ baseUrl
string CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.baseUrl
getset
This URL should not include query parameters. For example: https://tile.openstreetmap.org/{TileMatrix}/{TileCol}/{TileRow}.png
Definition at line 47 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ format
string CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.format
getset
The default value is "image/jpeg".
Definition at line 95 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ layer
string CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.layer
getset
Definition at line 63 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ maximumLevel
int CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.maximumLevel
getset
Only applicable if specifyZoomLevels is set to true.
Definition at line 364 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ minimumLevel
int CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.minimumLevel
getset
Definition at line 347 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ projection
CesiumWebMapTileServiceRasterOverlayProjection CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.projection
getset
For instance, EPSG:4326 uses geographic projection and EPSG:3857 uses Web Mercator.
Definition at line 182 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ rectangleEast
double CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.rectangleEast
getset
Specified in longitude degrees in the range [-180, 180]. Only applicable if specifyTilingScheme is set to true.
Definition at line 294 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ rectangleNorth
double CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.rectangleNorth
getset
Specified in latitude degrees in the range [-90, 90]. Only applicable if specifyTilingScheme is set to true.
Definition at line 312 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ rectangleSouth
double CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.rectangleSouth
getset
Definition at line 276 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ rectangleWest
double CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.rectangleWest
getset
Definition at line 258 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ rootTilesX
int CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.rootTilesX
getset
If specified, this determines the number of tiles at the root of the quadtree tiling scheme in the X direction. Only applicable if specifyTilingScheme is set to true.
Definition at line 220 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ rootTilesY
int CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.rootTilesY
getset
If specified, this determines the number of tiles at the root of the quadtree tiling scheme in the Y direction. Only applicable if specifyTilingScheme is set to true.
Definition at line 240 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ specifyTileMatrixSetLabels
bool CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.specifyTileMatrixSetLabels
getset
If false, the labels will be constructed from the specified levels and prefix (if one is specified).
Definition at line 148 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ specifyTilingScheme
bool CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.specifyTilingScheme
getset
If false, the tiling scheme will be deduced from the projection.
Definition at line 200 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ specifyZoomLevels
bool CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.specifyZoomLevels
getset
If false, the minimum and maximum zoom levels will be retrieved from the server's tilemapresource.xml file.
Definition at line 330 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ style
string CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.style
getset
Definition at line 79 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ tileHeight
int CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.tileHeight
getset
Definition at line 396 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ tileMatrixSetID
string CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.tileMatrixSetID
getset
Definition at line 111 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ tileMatrixSetLabelPrefix
string CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.tileMatrixSetLabelPrefix
getset
For instance, setting "EPSG:4326:" as the prefix generates the list ["EPSG:4326:0", "EPSG:4326:1", "EPSG:4326:2", ...]. Only applicable when specifyTileMatrixSetLabels is false.
Definition at line 130 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ tileMatrixSetLabels
List<string> CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.tileMatrixSetLabels
getset
Only applicable when specifyTileMatrixSetLabels is true.
Definition at line 165 of file CesiumWebMapTileServiceRasterOverlay.cs.
◆ tileWidth
int CesiumForUnity.CesiumWebMapTileServiceRasterOverlay.tileWidth
getset
Definition at line 380 of file CesiumWebMapTileServiceRasterOverlay.cs.
