Cesium for Unity 1.26.1
CesiumForUnity.CesiumUrlTemplateRasterOverlay Class Reference
A raster overlay that loads tiles from a templated URL. More...
Inheritance diagram for CesiumForUnity.CesiumUrlTemplateRasterOverlay:
Classes
class  HeaderEntry
 An HTTP header name paired with its specified value. More...
Protected Member Functions
Properties
string templateUrl [get, set]
 The URL containing template parameters that will be substituted when loading tiles.
CesiumUrlTemplateRasterOverlayProjection projection [get, set]
 The type of projection used to project the imagery onto the globe.
bool specifyTilingScheme [get, set]
 Set this to true to specify the quadtree tiling scheme according to the specified root tile numbers and projected bounding rectangle.
int rootTilesX [get, set]
 If specified, this determines the number of tiles at the root of the quadtree tiling scheme in the X direction.
int rootTilesY [get, set]
 If specified, this determines the number of tiles at the root of the quadtree tiling scheme in the Y direction.
double rectangleWest [get, set]
 The west boundary of the bounding rectangle used for the quadtree tiling scheme.
double rectangleSouth [get, set]
 The south boundary of the bounding rectangle used for the quadtree tiling scheme.
double rectangleEast [get, set]
 The east boundary of the bounding rectangle used for the quadtree tiling scheme.
double rectangleNorth [get, set]
 The north boundary of the bounding rectangle used for the quadtree tiling scheme.
int minimumLevel [get, set]
 Minimum zoom level.
int maximumLevel [get, set]
 Maximum zoom level.
int tileWidth [get, set]
 The pixel width of the image tiles.
int tileHeight [get, set]
 The pixel height of the image tiles.
List< HeaderEntry > requestHeaders [get, set]
 HTTP headers to be attached to each request made for this raster overlay.
string materialKey [get, set]
Additional Inherited Members
void AddToTileset ()
void RemoveFromTileset ()
void Refresh ()
Definition at line 30 of file CesiumUrlTemplateRasterOverlay.cs.
◆ AddToTileset()
override partial void CesiumForUnity.CesiumUrlTemplateRasterOverlay.AddToTileset ( Cesium3DTileset tileset)
protected
◆ RemoveFromTileset()
override partial void CesiumForUnity.CesiumUrlTemplateRasterOverlay.RemoveFromTileset ( Cesium3DTileset tileset)
protected
Property Documentation
◆ maximumLevel
int CesiumForUnity.CesiumUrlTemplateRasterOverlay.maximumLevel
getset
Maximum zoom level.
Definition at line 255 of file CesiumUrlTemplateRasterOverlay.cs.
◆ minimumLevel
int CesiumForUnity.CesiumUrlTemplateRasterOverlay.minimumLevel
getset
Minimum zoom level.
Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
Definition at line 238 of file CesiumUrlTemplateRasterOverlay.cs.
◆ projection
CesiumUrlTemplateRasterOverlayProjection CesiumForUnity.CesiumUrlTemplateRasterOverlay.projection
getset
For instance, EPSG:4326 uses geographic projection and EPSG:3857 uses Web Mercator.
Definition at line 85 of file CesiumUrlTemplateRasterOverlay.cs.
◆ rectangleEast
double CesiumForUnity.CesiumUrlTemplateRasterOverlay.rectangleEast
getset
Specified in longitude degrees in the range [-180, 180].
Only applicable if "Specify Tiling Scheme" is set to true.
Definition at line 198 of file CesiumUrlTemplateRasterOverlay.cs.
◆ rectangleNorth
double CesiumForUnity.CesiumUrlTemplateRasterOverlay.rectangleNorth
getset
Specified in latitude degrees in the range [-90, 90].
Definition at line 217 of file CesiumUrlTemplateRasterOverlay.cs.
◆ rectangleSouth
double CesiumForUnity.CesiumUrlTemplateRasterOverlay.rectangleSouth
getset
Definition at line 179 of file CesiumUrlTemplateRasterOverlay.cs.
◆ rectangleWest
double CesiumForUnity.CesiumUrlTemplateRasterOverlay.rectangleWest
getset
Definition at line 160 of file CesiumUrlTemplateRasterOverlay.cs.
◆ requestHeaders
List<HeaderEntry> CesiumForUnity.CesiumUrlTemplateRasterOverlay.requestHeaders
getset
Definition at line 305 of file CesiumUrlTemplateRasterOverlay.cs.
◆ rootTilesX
int CesiumForUnity.CesiumUrlTemplateRasterOverlay.rootTilesX
getset
Definition at line 122 of file CesiumUrlTemplateRasterOverlay.cs.
◆ rootTilesY
int CesiumForUnity.CesiumUrlTemplateRasterOverlay.rootTilesY
getset
Definition at line 141 of file CesiumUrlTemplateRasterOverlay.cs.
◆ specifyTilingScheme
bool CesiumForUnity.CesiumUrlTemplateRasterOverlay.specifyTilingScheme
getset
If false, the tiling scheme will be deduced from the projection.
Definition at line 103 of file CesiumUrlTemplateRasterOverlay.cs.
◆ templateUrl
string CesiumForUnity.CesiumUrlTemplateRasterOverlay.templateUrl
getset
The following template parameters are supported in url:
  • {x} - The tile X coordinate in the tiling scheme, where 0 is the westernmost tile.
  • {y} - The tile Y coordinate in the tiling scheme, where 0 is the southernmost tile.
  • {z} - The level of the tile in the tiling scheme, where 0 is the root of the quadtree pyramid.
  • {reverseX} - The tile X coordinate in the tiling scheme, where 0 is the easternmost tile.
  • {reverseY} - The tile Y coordinate in the tiling scheme, where 0 is the northernmost tile.
  • {reverseZ} - The tile Z coordinate in the tiling scheme, where 0 is equivalent to urlTemplateOptions.maximumLevel.
  • {westDegrees} - The western edge of the tile in geodetic degrees.
  • {southDegrees} - The southern edge of the tile in geodetic degrees.
  • {eastDegrees} - The eastern edge of the tile in geodetic degrees.
  • {northDegrees} - The northern edge of the tile in geodetic degrees.
  • {minimumX} - The minimum X coordinate of the tile's projected coordinates.
  • {minimumY} - The minimum Y coordinate of the tile's projected coordinates.
  • {maximumX} - The maximum X coordinate of the tile's projected coordinates.
  • {maximumY} - The maximum Y coordinate of the tile's projected coordinates.
  • {width} - The width of each tile in pixels.
  • {height} - The height of each tile in pixels.
Definition at line 67 of file CesiumUrlTemplateRasterOverlay.cs.
◆ tileHeight
int CesiumForUnity.CesiumUrlTemplateRasterOverlay.tileHeight
getset
Definition at line 289 of file CesiumUrlTemplateRasterOverlay.cs.
◆ tileWidth
int CesiumForUnity.CesiumUrlTemplateRasterOverlay.tileWidth
getset
Definition at line 272 of file CesiumUrlTemplateRasterOverlay.cs.
