Cesium for Unity 1.26.1
CesiumForUnity.CesiumTileExcluder Class Referenceabstract
The abstract base class for Cesium3DTileset tile excluders. More...
Inheritance diagram for CesiumForUnity.CesiumTileExcluder:
bool ShouldExclude (Cesium3DTile tile)
 Determines whether the given tile should be excluded from loading and rendering.
Protected Member Functions
virtual void OnEnable ()
virtual void OnDisable ()
By creating a class derived from CesiumTileExcluder, then adding it to a game object containing a Cesium3DTileset (or one of its parents), you can implement custom rules for excluding tiles in the Cesium3DTileset from loading and rendering.
Definition at line 14 of file CesiumTileExcluder.cs.
◆ OnDisable()
virtual void CesiumForUnity.CesiumTileExcluder.OnDisable ( )
inlineprotectedvirtual
Definition at line 35 of file CesiumTileExcluder.cs.
◆ OnEnable()
virtual void CesiumForUnity.CesiumTileExcluder.OnEnable ( )
Definition at line 26 of file CesiumTileExcluder.cs.
◆ ShouldExclude()
bool CesiumForUnity.CesiumTileExcluder.ShouldExclude ( Cesium3DTile tile)
abstract
If a tile is excluded, all of its children and other descendants in the bounding volume hierarchy will be excluded as well.
tileThe tile to check. This instance is only valid for the duration of this call. Saving it and using it later will result in undefined behavior, including crashes.
True if the tile should be excluded, false if the tile should be loaded and rendered.
