Cesium for Unity 1.26.1
A sub-scene with its own georeference origin. More...
| void | SetOriginEarthCenteredEarthFixed (double x, double y, double z) |
| Sets the origin of the coordinate system to particular ecefX, ecefY, ecefZ coordinates in the Earth-Centered, Earth-Fixed (ECEF) frame. | |
| void | SetOriginLongitudeLatitudeHeight (double longitude, double latitude, double height) |
| Sets the origin of the coordinate system to a particular longitude, latitude, and height. | |
| void | UpdateOrigin () |
| Recomputes the coordinate system based on an updated origin. | |
Properties | |
| double | activationRadius [get, set] |
| The maximum distance at which to activate this sub-scene, in meters. | |
| bool | showActivationRadius [get, set] |
| Whether to show the activation radius as a wireframe sphere in the Editor. | |
| CesiumGeoreferenceOriginAuthority | originAuthority [get, set] |
| Identifies which set of coordinates authoritatively defines the origin of this sub-scene. | |
| double | latitude [get, set] |
| The latitude of the origin of the coordinate system, in degrees, in the range -90 to 90. | |
| double | longitude [get, set] |
| The longitude of the origin of the coordinate system, in degrees, in the range -180 to 180. | |
| double | height [get, set] |
| The height in the origin of the coordinate system, in meters above the ellipsoid. | |
| double | ecefX [get, set] |
| The Earth-Centered, Earth-Fixed X coordinate of the origin of the coordinate system, in meters. | |
| double | ecefY [get, set] |
| The Earth-Centered, Earth-Fixed Y coordinate of the origin of the coordinate system, in meters. | |
| double | ecefZ [get, set] |
| The Earth-Centered, Earth-Fixed Z coordinate of the origin of the coordinate system, in meters. | |
When a game object with a CesiumOriginShift comes close to a sub-scene, that sub-scene is activated and all other sub-scenes are deactivated. This allows relatively normal Unity scenes to be designed at multiple locations on the globe.
When determining the distance to a sub-scene, only the CesiumGeoreference's Transform is considered. The Transform associated with the sub-scene is ignored. The sub-scene transform will affect the transformation of the objects inside it once activated, however.
Definition at line 22 of file CesiumSubScene.cs.
Calling this method is more efficient than setting the properties individually.
| x | The X coordinate in meters. |
| y | The Y coordinate in meters. |
| z | The Z coordinate in meters. |
Definition at line 224 of file CesiumSubScene.cs.
| longitude | The longitude in degrees, in the range -180 to 180. |
| latitude | The latitude in degrees, in the range -90 to 90. |
| height | The height in meters above the ellipsoid. Do not confuse this with a geoid height or height above mean sea level, which can be tens of meters higher or lower depending on where in the world the object is located. |
Definition at line 246 of file CesiumSubScene.cs.
It is usually not necessary to call this directly as it is called automatically when needed.
Definition at line 431 of file CesiumSubScene.cs.
getset |
Even if the CesiumOriginShift game object is inside this activation radius, this sub-scene may still not be activated if another sub-scene is closer.
Definition at line 39 of file CesiumSubScene.cs.
getset |
This property is ignored unless originAuthority is CesiumGeoreferenceOriginAuthority.EarthCenteredEarthFixed. Setting this property changes the originAuthority accordingly.
Definition at line 146 of file CesiumSubScene.cs.
getset |
Definition at line 165 of file CesiumSubScene.cs.
getset |
Definition at line 184 of file CesiumSubScene.cs.
getset |
Do not confuse this with a geoid height or height above mean sea level, which can be tens of meters higher or lower depending on where in the world the object is located. This property is ignored unless originAuthority is CesiumGeoreferenceOriginAuthority.LongitudeLatitudeHeight. Setting this property changes the originAuthority accordingly.
Definition at line 127 of file CesiumSubScene.cs.
getset |
Definition at line 87 of file CesiumSubScene.cs.
getset |
Definition at line 106 of file CesiumSubScene.cs.
getset |
Definition at line 68 of file CesiumSubScene.cs.
getset |
Definition at line 54 of file CesiumSubScene.cs.
