Cesium for Unity 1.26.1
CesiumForUnity.CesiumRuntimeSettings Class Referencesealed
Holds Cesium settings used at runtime. More...
Inheritance diagram for CesiumForUnity.CesiumRuntimeSettings:
Properties
static CesiumRuntimeSettings instance [get]
 Gets the singleton instance of this class.
static string defaultIonAccessTokenID [get]
 The ID of the default Cesium ion access token to use within the project.
static string defaultIonAccessToken [get]
 The default Cesium ion access token value to use within the project.
static int requestsPerCachePrune [get]
 The number of requests to handle before each prune of old cached results from the database.
static ulong maxItems [get]
 The maximum number of items should be kept in the Sqlite database after pruning.
Definition at line 14 of file CesiumRuntimeSettings.cs.
Property Documentation
◆ defaultIonAccessToken
string CesiumForUnity.CesiumRuntimeSettings.defaultIonAccessToken
staticget
Definition at line 151 of file CesiumRuntimeSettings.cs.
◆ defaultIonAccessTokenID
string CesiumForUnity.CesiumRuntimeSettings.defaultIonAccessTokenID
staticget
Definition at line 130 of file CesiumRuntimeSettings.cs.
◆ instance
CesiumRuntimeSettings CesiumForUnity.CesiumRuntimeSettings.instance
staticget
If the project does not yet contain an instance, one is created and added at the specified file path.
Definition at line 26 of file CesiumRuntimeSettings.cs.
◆ maxItems
ulong CesiumForUnity.CesiumRuntimeSettings.maxItems
staticget
Definition at line 183 of file CesiumRuntimeSettings.cs.
◆ requestsPerCachePrune
int CesiumForUnity.CesiumRuntimeSettings.requestsPerCachePrune
staticget
Definition at line 172 of file CesiumRuntimeSettings.cs.
