cesium-native 0.67.0
The following are the thread safety rules and patterns employed by Cesium Native. We can think of this as a contract. Anyone implementing functionality in Cesium Native must ensure that they are fulfilling this contract. Anyone using functionality in Cesium Native can use it with confidence that the contract has been fulfilled.
In rare cases, this contract cannot be fulfilled. When that happens, the points of divergence must be documented very clearly. If the divergence is likely to be surprising, consider capturing the divergence in naming as well. For example, CesiumUtility::ReferenceCountedNonThreadSafe does not follow the usual rules.
These rules probably won't be surprising, and they also should not impose a large burden on implementers in most cases.
Threads can simultaneously create and use their own private instances of a given class or struct, without any concerns about thread safety.
However, you must also consider the thread safety of any arguments passed to the constructor or any methods that you call. If any of them are shared between threads, then that usage must also be safe according to these rules.
This rule is usually satisfied without any particular effort from the implementer. However, if the instance accesses shared, mutable state (static fields, global variables, singletons), then access to this shared state must be serialized using a std::mutex.
It is safe to call a static method from multiple threads simultaneously.
You must also consider the thread safety of any arguments passed to the static method. If any of them are shared between threads, then that usage must also be safe according to these rules.
A static method often operates only on the arguments passed to it. As long as those arguments are not shared between threads (or are safe to use in this way), the static method itself will be safe to use from multiple threads simultaneously without any particular effort from the implementer.
When the static method accesses static fields, global variables, or singletons, more care must be taken by the implementer in order to satisfy this rule. If there is any possibility of the shared data changing (i.e., it's not completely immutable), a synchronization primitive such as a std::mutex must be used to serialize access to the shared data.
const.It is safe to share a single instance of a class or struct between threads as long as all threads are restricted to const access of the instance.
If even a single thread is or may be modifying the instance, then it is NOT safe for any other thread to access the instance in any way.
Note that if this instance references other instances, then those other instances must also be safe to use according to these rules.
This rule is usually satisfied without any particular effort from the implementer. However, there are a few cases to be aware of:
mutable, it means that field can be modified even via const access. To conform to this rule, access to that field must be serialized with a std::mutex. Often, the presence of a mutable field indicates a type that cannot realistically conform to these rules, and it should be documented as such.const_cast is always a potentially dangerous thing to do. However, according to these rules, it can also introduce thread safety concerns.const is not transitive through pointers and references. For example, in a type like this:It is perfectly allowed to modify the target of p via a const reference to Foo, like this:
This is also true if p is a reference, a std::unique_ptr, a std::span, etc. However, other types like std::vector do not behave this way.
Implementers should take care not to abuse this behavior. An implementation that modifies a referenced object from a const method is very likely to run afoul of these rules.
