CesiumRasterOverlays::WebMapServiceRasterOverlayOptions Struct Reference
Options for Web Map Service (WMS) overlays. More...
#include <CesiumRasterOverlays/WebMapServiceRasterOverlay.h>
std::string version = "1.3.0"
 The Web Map Service version. The default is "1.3.0".
std::string layers
 Comma separated Web Map Service layer names to request.
std::string format = "image/png"
 The image format to request, expressed as a MIME type to be given to the server. The default is "image/png".
std::optional< std::string > credit
int32_t minimumLevel = 0
 The minimum level-of-detail supported by the imagery provider.
int32_t maximumLevel = 14
 The maximum level-of-detail supported by the imagery provider.
int32_t tileWidth = 256
 Pixel width of image tiles.
int32_t tileHeight = 256
 Pixel height of image tiles.
Definition at line 18 of file WebMapServiceRasterOverlay.h.
◆ credit
std::optional<std::string> CesiumRasterOverlays::WebMapServiceRasterOverlayOptions::credit
Definition at line 39 of file WebMapServiceRasterOverlay.h.
◆ format
std::string CesiumRasterOverlays::WebMapServiceRasterOverlayOptions::format = "image/png"
Definition at line 34 of file WebMapServiceRasterOverlay.h.
◆ layers
std::string CesiumRasterOverlays::WebMapServiceRasterOverlayOptions::layers
Definition at line 28 of file WebMapServiceRasterOverlay.h.
◆ maximumLevel
int32_t CesiumRasterOverlays::WebMapServiceRasterOverlayOptions::maximumLevel = 14
Definition at line 53 of file WebMapServiceRasterOverlay.h.
◆ minimumLevel
int32_t CesiumRasterOverlays::WebMapServiceRasterOverlayOptions::minimumLevel = 0
Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
Definition at line 48 of file WebMapServiceRasterOverlay.h.
◆ tileHeight
int32_t CesiumRasterOverlays::WebMapServiceRasterOverlayOptions::tileHeight = 256
Definition at line 63 of file WebMapServiceRasterOverlay.h.
◆ tileWidth
int32_t CesiumRasterOverlays::WebMapServiceRasterOverlayOptions::tileWidth = 256
Definition at line 58 of file WebMapServiceRasterOverlay.h.
◆ version
std::string CesiumRasterOverlays::WebMapServiceRasterOverlayOptions::version = "1.3.0"
Definition at line 23 of file WebMapServiceRasterOverlay.h.
