CesiumGltfWriter::SchemaWriterResult Struct Reference
The result of writing a schema with SchemaWriter::writeSchema. More...
#include <CesiumGltfWriter/SchemaWriter.h>
std::vector< std::byte > schemaBytes
 The final generated std::vector<std::byte> of the schema JSON.
Definition at line 17 of file SchemaWriter.h.
◆ errors
std::vector<std::string> CesiumGltfWriter::SchemaWriterResult::errors
Definition at line 26 of file SchemaWriter.h.
◆ schemaBytes
std::vector<std::byte> CesiumGltfWriter::SchemaWriterResult::schemaBytes
Definition at line 21 of file SchemaWriter.h.
◆ warnings
std::vector<std::string> CesiumGltfWriter::SchemaWriterResult::warnings
Definition at line 31 of file SchemaWriter.h.
