cesium-native 0.67.0
Options used to configure the OAuth2 authentication process. More...
#include <CesiumClientCommon/OAuth2PKCE.h>
| std::string | clientID |
| The OAuth2 client ID. | |
| std::string | redirectPath |
| The URL path that will be used to create the redirect URI. | |
| std::optional< int > | redirectPort = std::nullopt |
| The port that the internal HTTP server will listen on. | |
| bool | useJsonBody |
| Whether requests against the token and refresh endpoints should use a JSON body to the POST request. | |
Definition at line 36 of file OAuth2PKCE.h.
| std::string CesiumClientCommon::OAuth2ClientOptions::clientID |
Definition at line 40 of file OAuth2PKCE.h.
| std::string CesiumClientCommon::OAuth2ClientOptions::redirectPath |
The final redirect URI will be http://127.0.0.1:<redirectPort>/<redirectPath>. This should match what is configured in the developer settings for the service you are authenticating with.
Definition at line 49 of file OAuth2PKCE.h.
| std::optional<int> CesiumClientCommon::OAuth2ClientOptions::redirectPort = std::nullopt |
If this is std::nullopt, a random available port will be chosen. You may need to explicitly specify the port if the API you are authenticating with requires a specific port to be provided in the developer settings.
Definition at line 57 of file OAuth2PKCE.h.
| bool CesiumClientCommon::OAuth2ClientOptions::useJsonBody |
If false, the body will be specified in the application/x-www-form-urlencoded format.
Definition at line 65 of file OAuth2PKCE.h.
