cesium-native 0.67.0
Reads Schema instances from JSON. More...
#include <CesiumTilesetJsonReader/SchemaReader.h>
| SchemaReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Schema > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of Schema from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Schema > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of Schema from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Schema > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of Schema from a rapidJson::Value. | |
Definition at line 24 of file SchemaReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Schema > > CesiumTilesetJsonReader::SchemaReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Schema > CesiumTilesetJsonReader::SchemaReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Schema > CesiumTilesetJsonReader::SchemaReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
