cesium-native 0.67.0
Reads ExtensionTilesetMaxarContentGeoJson instances from JSON. More...
#include <CesiumTilesetJsonReader/ExtensionTilesetMaxarContentGeoJsonReader.h>
| ExtensionTilesetMaxarContentGeoJsonReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ExtensionTilesetMaxarContentGeoJson > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of ExtensionTilesetMaxarContentGeoJson from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ExtensionTilesetMaxarContentGeoJson > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of ExtensionTilesetMaxarContentGeoJson from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ExtensionTilesetMaxarContentGeoJson > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of ExtensionTilesetMaxarContentGeoJson from a rapidJson::Value. | |
Definition at line 25 of file ExtensionTilesetMaxarContentGeoJsonReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ExtensionTilesetMaxarContentGeoJson > > CesiumTilesetJsonReader::ExtensionTilesetMaxarContentGeoJsonReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ExtensionTilesetMaxarContentGeoJson > CesiumTilesetJsonReader::ExtensionTilesetMaxarContentGeoJsonReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ExtensionTilesetMaxarContentGeoJson > CesiumTilesetJsonReader::ExtensionTilesetMaxarContentGeoJsonReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
