CesiumTilesetJsonReader::Extension3dTilesContentConditionalReader Class Reference
Reads Extension3dTilesContentConditional instances from JSON. More...
#include <CesiumTilesetJsonReader/Extension3dTilesContentConditionalReader.h>
 Extension3dTilesContentConditionalReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesContentConditional > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Extension3dTilesContentConditional from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesContentConditional > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Extension3dTilesContentConditional from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Extension3dTilesContentConditional > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Extension3dTilesContentConditional from a rapidJson::Value.
Definition at line 25 of file Extension3dTilesContentConditionalReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Extension3dTilesContentConditional > > CesiumTilesetJsonReader::Extension3dTilesContentConditionalReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesContentConditional > CesiumTilesetJsonReader::Extension3dTilesContentConditionalReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesContentConditional > CesiumTilesetJsonReader::Extension3dTilesContentConditionalReader::readFromJson ( const std::span< const std::byte > & data) const
