cesium-native 0.67.0
Reads Extension3dTilesBoundingVolumeCylinder instances from JSON. More...
#include <CesiumTilesetJsonReader/Extension3dTilesBoundingVolumeCylinderReader.h>
| Extension3dTilesBoundingVolumeCylinderReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesBoundingVolumeCylinder > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of Extension3dTilesBoundingVolumeCylinder from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesBoundingVolumeCylinder > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of Extension3dTilesBoundingVolumeCylinder from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Extension3dTilesBoundingVolumeCylinder > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of Extension3dTilesBoundingVolumeCylinder from a rapidJson::Value. | |
Definition at line 25 of file Extension3dTilesBoundingVolumeCylinderReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::Extension3dTilesBoundingVolumeCylinder > > CesiumTilesetJsonReader::Extension3dTilesBoundingVolumeCylinderReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesBoundingVolumeCylinder > CesiumTilesetJsonReader::Extension3dTilesBoundingVolumeCylinderReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::Extension3dTilesBoundingVolumeCylinder > CesiumTilesetJsonReader::Extension3dTilesBoundingVolumeCylinderReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
