CesiumTilesetJsonReader::ConditionalContentReader Class Reference
Reads ConditionalContent instances from JSON. More...
#include <CesiumTilesetJsonReader/ConditionalContentReader.h>
 ConditionalContentReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ConditionalContent > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ConditionalContent from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ConditionalContent > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ConditionalContent from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ConditionalContent > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ConditionalContent from a rapidJson::Value.
Definition at line 25 of file ConditionalContentReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ConditionalContent > > CesiumTilesetJsonReader::ConditionalContentReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ConditionalContent > CesiumTilesetJsonReader::ConditionalContentReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ConditionalContent > CesiumTilesetJsonReader::ConditionalContentReader::readFromJson ( const std::span< const std::byte > & data) const
