CesiumTilesetJsonReader::ClassStatisticsReader Class Reference
Reads ClassStatistics instances from JSON. More...
#include <CesiumTilesetJsonReader/ClassStatisticsReader.h>
 ClassStatisticsReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ClassStatistics > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ClassStatistics from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ClassStatistics > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ClassStatistics from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ClassStatistics > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ClassStatistics from a rapidJson::Value.
Definition at line 25 of file ClassStatisticsReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::ClassStatistics > > CesiumTilesetJsonReader::ClassStatisticsReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ClassStatistics > CesiumTilesetJsonReader::ClassStatisticsReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::ClassStatistics > CesiumTilesetJsonReader::ClassStatisticsReader::readFromJson ( const std::span< const std::byte > & data) const
