CesiumTilesetJsonReader::BoundingVolumeReader Class Reference
Reads BoundingVolume instances from JSON. More...
#include <CesiumTilesetJsonReader/BoundingVolumeReader.h>
 BoundingVolumeReader ()
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::BoundingVolume > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of BoundingVolume from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::BoundingVolume > readFromJson (const rapidjson::Value &value) const
 Reads an instance of BoundingVolume from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::BoundingVolume > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of BoundingVolume from a rapidJson::Value.
Definition at line 25 of file BoundingVolumeReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumTilesetJson::BoundingVolume > > CesiumTilesetJsonReader::BoundingVolumeReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::BoundingVolume > CesiumTilesetJsonReader::BoundingVolumeReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumTilesetJson::BoundingVolume > CesiumTilesetJsonReader::BoundingVolumeReader::readFromJson ( const std::span< const std::byte > & data) const
