CesiumJsonWriter::PrettyJsonWriter Member List
This is the complete list of members for CesiumJsonWriter::PrettyJsonWriter, including all inherited members.
Bool(bool b) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Double(double d) overrideCesiumJsonWriter::PrettyJsonWritervirtual
emplaceError(ErrorStr &&error)CesiumJsonWriter::JsonWriterinline
emplaceWarning(WarningStr &&warning)CesiumJsonWriter::JsonWriterinline
EndArray() overrideCesiumJsonWriter::PrettyJsonWritervirtual
EndObject() overrideCesiumJsonWriter::PrettyJsonWritervirtual
getErrors() constCesiumJsonWriter::JsonWriterinline
getWarnings() constCesiumJsonWriter::JsonWriterinline
Int(int i) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Int64(std::int64_t i) overrideCesiumJsonWriter::PrettyJsonWritervirtual
JsonWriter() (defined in CesiumJsonWriter::JsonWriter)CesiumJsonWriter::JsonWriter
Key(std::string_view string) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyArray(std::string_view keyName, const std::function< void(void)> &insideArray) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyObject(std::string_view keyName, const std::function< void(void)> &insideObject) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyPrimitive(std::string_view keyName, std::int32_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyPrimitive(std::string_view keyName, std::uint32_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyPrimitive(std::string_view keyName, std::int64_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyPrimitive(std::string_view keyName, std::uint64_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyPrimitive(std::string_view keyName, std::string_view value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyPrimitive(std::string_view keyName, float value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyPrimitive(std::string_view keyName, double value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
KeyPrimitive(std::string_view keyName, std::nullptr_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Null() overrideCesiumJsonWriter::PrettyJsonWritervirtual
PrettyJsonWriter() noexcept (defined in CesiumJsonWriter::PrettyJsonWriter)CesiumJsonWriter::PrettyJsonWriter
Primitive(std::int32_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Primitive(std::uint32_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Primitive(std::int64_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Primitive(std::uint64_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Primitive(float value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Primitive(double value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Primitive(std::nullptr_t value) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Primitive(std::string_view string) overrideCesiumJsonWriter::PrettyJsonWritervirtual
RawNumber(const char *str, unsigned int length, bool copy) overrideCesiumJsonWriter::PrettyJsonWritervirtual
StartArray() overrideCesiumJsonWriter::PrettyJsonWritervirtual
StartObject() overrideCesiumJsonWriter::PrettyJsonWritervirtual
String(std::string_view string) overrideCesiumJsonWriter::PrettyJsonWritervirtual
toBytes() overrideCesiumJsonWriter::PrettyJsonWritervirtual
toString() overrideCesiumJsonWriter::PrettyJsonWritervirtual
toStringView() overrideCesiumJsonWriter::PrettyJsonWritervirtual
Uint(unsigned int i) overrideCesiumJsonWriter::PrettyJsonWritervirtual
Uint64(std::uint64_t i) overrideCesiumJsonWriter::PrettyJsonWritervirtual
~JsonWriter()=default (defined in CesiumJsonWriter::JsonWriter)CesiumJsonWriter::JsonWritervirtual
~PrettyJsonWriter()=default (defined in CesiumJsonWriter::PrettyJsonWriter)CesiumJsonWriter::PrettyJsonWriter
