CesiumGltfReader::SpotlightReader Class Reference
Reads Spotlight instances from JSON. More...
#include <CesiumGltfReader/SpotlightReader.h>
 SpotlightReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Spotlight > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Spotlight from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Spotlight > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Spotlight from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Spotlight > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Spotlight from a rapidJson::Value.
Definition at line 24 of file SpotlightReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Spotlight > > CesiumGltfReader::SpotlightReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Spotlight > CesiumGltfReader::SpotlightReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Spotlight > CesiumGltfReader::SpotlightReader::readFromJson ( const std::span< const std::byte > & data) const
