CesiumGltfReader::SphereReader Class Reference
Reads Sphere instances from JSON. More...
#include <CesiumGltfReader/SphereReader.h>
 SphereReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Sphere > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Sphere from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Sphere > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Sphere from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Sphere > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Sphere from a rapidJson::Value.
Definition at line 24 of file SphereReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Sphere > > CesiumGltfReader::SphereReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Sphere > CesiumGltfReader::SphereReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Sphere > CesiumGltfReader::SphereReader::readFromJson ( const std::span< const std::byte > & data) const
