CesiumGltfReader::ExtensionModelKhrLightsPunctualReader Class Reference
Reads ExtensionModelKhrLightsPunctual instances from JSON. More...
#include <CesiumGltfReader/ExtensionModelKhrLightsPunctualReader.h>
 ExtensionModelKhrLightsPunctualReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelKhrLightsPunctual > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionModelKhrLightsPunctual from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelKhrLightsPunctual > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionModelKhrLightsPunctual from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionModelKhrLightsPunctual > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionModelKhrLightsPunctual from a rapidJson::Value.
Definition at line 25 of file ExtensionModelKhrLightsPunctualReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionModelKhrLightsPunctual > > CesiumGltfReader::ExtensionModelKhrLightsPunctualReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelKhrLightsPunctual > CesiumGltfReader::ExtensionModelKhrLightsPunctualReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionModelKhrLightsPunctual > CesiumGltfReader::ExtensionModelKhrLightsPunctualReader::readFromJson ( const std::span< const std::byte > & data) const
