CesiumGltfReader::ExtensionMeshPrimitiveBentleyMaterialsLineStyleReader Class Reference
Reads ExtensionMeshPrimitiveBentleyMaterialsLineStyle instances from JSON. More...
#include <CesiumGltfReader/ExtensionMeshPrimitiveBentleyMaterialsLineStyleReader.h>
 ExtensionMeshPrimitiveBentleyMaterialsLineStyleReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveBentleyMaterialsLineStyle > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionMeshPrimitiveBentleyMaterialsLineStyle from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveBentleyMaterialsLineStyle > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionMeshPrimitiveBentleyMaterialsLineStyle from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMeshPrimitiveBentleyMaterialsLineStyle > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionMeshPrimitiveBentleyMaterialsLineStyle from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionMeshPrimitiveBentleyMaterialsLineStyle > > CesiumGltfReader::ExtensionMeshPrimitiveBentleyMaterialsLineStyleReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveBentleyMaterialsLineStyle > CesiumGltfReader::ExtensionMeshPrimitiveBentleyMaterialsLineStyleReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionMeshPrimitiveBentleyMaterialsLineStyle > CesiumGltfReader::ExtensionMeshPrimitiveBentleyMaterialsLineStyleReader::readFromJson ( const std::span< const std::byte > & data) const
