CesiumGltfReader::ExtensionKhrImplicitShapesSphereReader Class Reference
Reads ExtensionKhrImplicitShapesSphere instances from JSON. More...
#include <CesiumGltfReader/ExtensionKhrImplicitShapesSphereReader.h>
 ExtensionKhrImplicitShapesSphereReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesSphere > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionKhrImplicitShapesSphere from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesSphere > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionKhrImplicitShapesSphere from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrImplicitShapesSphere > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionKhrImplicitShapesSphere from a rapidJson::Value.
Definition at line 25 of file ExtensionKhrImplicitShapesSphereReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrImplicitShapesSphere > > CesiumGltfReader::ExtensionKhrImplicitShapesSphereReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesSphere > CesiumGltfReader::ExtensionKhrImplicitShapesSphereReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesSphere > CesiumGltfReader::ExtensionKhrImplicitShapesSphereReader::readFromJson ( const std::span< const std::byte > & data) const
