CesiumGltfReader::ExtensionKhrGaussianSplattingCompressionSpz2Reader Class Reference
Reads ExtensionKhrGaussianSplattingCompressionSpz2 instances from JSON. More...
#include <CesiumGltfReader/ExtensionKhrGaussianSplattingCompressionSpz2Reader.h>
 ExtensionKhrGaussianSplattingCompressionSpz2Reader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplattingCompressionSpz2 > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionKhrGaussianSplattingCompressionSpz2 from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplattingCompressionSpz2 > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionKhrGaussianSplattingCompressionSpz2 from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrGaussianSplattingCompressionSpz2 > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionKhrGaussianSplattingCompressionSpz2 from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrGaussianSplattingCompressionSpz2 > > CesiumGltfReader::ExtensionKhrGaussianSplattingCompressionSpz2Reader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplattingCompressionSpz2 > CesiumGltfReader::ExtensionKhrGaussianSplattingCompressionSpz2Reader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplattingCompressionSpz2 > CesiumGltfReader::ExtensionKhrGaussianSplattingCompressionSpz2Reader::readFromJson ( const std::span< const std::byte > & data) const
