CesiumGltfReader::ExtensionExtVoxelsExtStructuralMetadataReader Class Reference
Reads ExtensionExtVoxelsExtStructuralMetadata instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtVoxelsExtStructuralMetadataReader.h>
 ExtensionExtVoxelsExtStructuralMetadataReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtVoxelsExtStructuralMetadata > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtVoxelsExtStructuralMetadata from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtVoxelsExtStructuralMetadata > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtVoxelsExtStructuralMetadata from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtVoxelsExtStructuralMetadata > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtVoxelsExtStructuralMetadata from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtVoxelsExtStructuralMetadata > > CesiumGltfReader::ExtensionExtVoxelsExtStructuralMetadataReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtVoxelsExtStructuralMetadata > CesiumGltfReader::ExtensionExtVoxelsExtStructuralMetadataReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtVoxelsExtStructuralMetadata > CesiumGltfReader::ExtensionExtVoxelsExtStructuralMetadataReader::readFromJson ( const std::span< const std::byte > & data) const
