CesiumGltfReader::ContentReader Class Reference
Reads Content instances from JSON. More...
#include <CesiumGltfReader/ContentReader.h>
 ContentReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Content > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Content from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Content > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Content from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Content > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Content from a rapidJson::Value.
Definition at line 24 of file ContentReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Content > > CesiumGltfReader::ContentReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Content > CesiumGltfReader::ContentReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Content > CesiumGltfReader::ContentReader::readFromJson ( const std::span< const std::byte > & data) const
