cesium-native 0.65.0
Cesium3DTilesReader::Extension3dTilesBoundingVolumeS2Reader Class Reference
Reads Extension3dTilesBoundingVolumeS2 instances from JSON. More...
#include <Cesium3DTilesReader/Extension3dTilesBoundingVolumeS2Reader.h>
 Extension3dTilesBoundingVolumeS2Reader ()
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesBoundingVolumeS2 > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Extension3dTilesBoundingVolumeS2 from a byte buffer.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesBoundingVolumeS2 > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Extension3dTilesBoundingVolumeS2 from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Extension3dTilesBoundingVolumeS2 > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Extension3dTilesBoundingVolumeS2 from a rapidJson::Value.
Definition at line 25 of file Extension3dTilesBoundingVolumeS2Reader.h.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Extension3dTilesBoundingVolumeS2 > > Cesium3DTilesReader::Extension3dTilesBoundingVolumeS2Reader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesBoundingVolumeS2 > Cesium3DTilesReader::Extension3dTilesBoundingVolumeS2Reader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesBoundingVolumeS2 > Cesium3DTilesReader::Extension3dTilesBoundingVolumeS2Reader::readFromJson ( const std::span< const std::byte > & data) const
