cesium-native 0.65.0
PaddingReader.h
5#include <Cesium3DTiles/Padding.h>
6#include <Cesium3DTilesReader/Library.h>
9
10#include <rapidjson/fwd.h>
11
12#include <span>
13#include <vector>
14
15namespace Cesium3DTiles {
16struct Padding;
17} // namespace Cesium3DTiles
18
19namespace Cesium3DTilesReader {
20
71
72} // namespace Cesium3DTilesReader
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Padding > readFromJson(const rapidjson::Value &value) const
Reads an instance of Padding from a rapidJson::Value.
PaddingReader()
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Padding > > readArrayFromJson(const rapidjson::Value &value) const
Reads an array of instances of Padding from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Padding > readFromJson(const std::span< const std::byte > &data) const
Reads an instance of Padding from a byte buffer.
Classes for reading 3D Tiles.
Definition Library.h:8
Classes for using 3D Tiles.
Definition Buffer.h:7
The padding property specifies how many rows of attribute data in each dimension come from neighborin...
Definition Padding.h:17
Definition JsonReader.h:23
