cesium-native 0.65.0
AvailabilityReader.h
5#include <Cesium3DTiles/Availability.h>
6#include <Cesium3DTilesReader/Library.h>
9
10#include <rapidjson/fwd.h>
11
12#include <span>
13#include <vector>
14
15namespace Cesium3DTiles {
16struct Availability;
17} // namespace Cesium3DTiles
18
19namespace Cesium3DTilesReader {
20
72
73} // namespace Cesium3DTilesReader
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Availability > readFromJson(const std::span< const std::byte > &data) const
Reads an instance of Availability from a byte buffer.
AvailabilityReader()
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Availability > > readArrayFromJson(const rapidjson::Value &value) const
Reads an array of instances of Availability from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Availability > readFromJson(const rapidjson::Value &value) const
Reads an instance of Availability from a rapidJson::Value.
Classes for reading 3D Tiles.
Definition Library.h:8
Classes for using 3D Tiles.
Definition Buffer.h:7
An object describing the availability of a set of elements.
Definition JsonReader.h:23
