Create labels by calling
LabelCollection#add. Do not call the constructor directly.
Throws:
DeveloperError : distanceDisplayCondition.far must be greater than distanceDisplayCondition.near
Default Value:
false
Examples:
// Example 1.
const myLabelEntity = viewer.entities.add({
label: {
// Example 2.
label: {
text: 'English text'
backgroundColor : Color
Default Value:
new Color(0.165, 0.165, 0.165, 0.8)
Gets or sets the background padding, in pixels, of this label. The
x value
controls horizontal padding, and the y value controls vertical padding.
Default Value:
new Cartesian2(7, 5)
Gets or sets the distance from the camera at which to disable the depth test to, for example, prevent clipping against terrain.
When set to zero, the depth test is always applied. When set to Number.POSITIVE_INFINITY, the depth test is never applied.
Default Value:
undefined
eyeOffset : Cartesian3
Gets and sets the 3D Cartesian offset applied to this label in eye coordinates. Eye coordinates is a left-handed
coordinate system, where
x points towards the viewer's right, y points up, and
z points into the screen. Eye coordinates use the same scale as world and model coordinates,
which is typically meters.
l.eyeOffset = new Cartesian3(0.0, 8000000.0, 0.0);-
Default Value:
Cartesian3.ZERO
fillColor : Color
Default Value:
Color.WHITE
Default Value:
'30px sans-serif'
Default Value:
HeightReference.NONE
Gets or sets the horizontal origin of this label, which determines if the label is drawn
to the left, center, or right of its anchor position.
Default Value:
HorizontalOrigin.LEFT
// Use a top, right origin
outlineColor : Color
Default Value:
Color.BLACK
Default Value:
1.0
pixelOffset : Cartesian2
Gets or sets the pixel offset in screen space from the origin of this label. This is commonly used
to align multiple labels and billboards at the same position, e.g., an image and text. The
screen space origin is the top, left corner of the canvas;
x increases from
left to right, and y increases from top to bottom.
default |
l.pixeloffset = new Cartesian2(25, 75); |
Default Value:
Cartesian2.ZERO
Gets or sets near and far pixel offset scaling properties of a Label based on the Label's distance from the camera.
A label's pixel offset will be scaled between the
NearFarScalar#nearValue and
NearFarScalar#farValue while the camera distance falls within the lower and upper bounds
of the specified NearFarScalar#near and NearFarScalar#far.
Outside of these ranges the label's pixel offset scaling remains clamped to the nearest bound. If undefined,
pixelOffsetScaleByDistance will be disabled.
Examples:
// Example 1.
// Example 2.
position : Cartesian3
Gets or sets the uniform scale that is multiplied with the label's size in pixels.
A scale of
Applying a large scale value may pixelate the label. To make text larger without pixelation, use a larger font size when calling
From left to right in the above image, the scales are
1.0 does not change the size of the label; a scale greater than
1.0 enlarges the label; a positive scale less than 1.0 shrinks
the label.
Label#font instead.
0.5, 1.0,
and 2.0.
Default Value:
1.0
Gets or sets near and far scaling properties of a Label based on the label's distance from the camera.
A label's scale will interpolate between the
Outside of these ranges the label's scale remains clamped to the nearest bound. If undefined,
scaleByDistance will be disabled.
Examples:
// Example 1.
// Example 2.
Determines if this label will be shown. Use this to hide or show a label, instead
of removing it and re-adding it to the collection.
Default Value:
true
Default Value:
false
style : LabelStyle
Default Value:
LabelStyle.FILL
Gets the total scale of the label, which is the label's scale multiplied by the computed relative size
of the desired font compared to the generated glyph size.
Default Value:
1.0
Gets or sets near and far translucency properties of a Label based on the Label's distance from the camera.
A label's translucency will interpolate between the
Outside of these ranges the label's translucency remains clamped to the nearest bound. If undefined,
translucencyByDistance will be disabled.
Examples:
// Example 1.
// Example 2.
Gets or sets the vertical origin of this label, which determines if the label is
to the above, below, or at the center of its anchor position.
Default Value:
VerticalOrigin.BASELINE
Computes the screen-space position of the label's origin, taking into account eye and pixel offsets.
The screen space origin is the top, left corner of the canvas;
x increases from
| Name | Type | Description |
scene |
Scene | The scene the label is in. |
result |
Cartesian2 | optional The object onto which to store the result. |
Determines if this label equals another label. Labels are equal if all their properties
are equal. Labels in different collections can be equal.
other |
Label | The label to compare for equality. |
isDestroyed will result in a DeveloperError exception.
