new Label()
LabelCollection#add.
Throws:
Demo:
Source:
Scene/Label.js, line 61
eyeOffset :Cartesian3
Gets and sets the 3D Cartesian offset applied to this label in eye coordinates. Eye coordinates is a left-handed coordinate system, where
xpoints towards the viewer's right,ypoints up, andzpoints into the screen. Eye coordinates use the same scale as world and model coordinates, which is typically meters.
Source: Scene/Label.js, line 465 -
fillColor :Color
font :String
horizontalOrigin :HorizontalOrigin
// Use a top, right origin l.horizontalOrigin = Cesium.HorizontalOrigin.RIGHT; l.verticalOrigin = Cesium.VerticalOrigin.TOP;Source: Scene/Label.js, line 505 -
Gets or sets the user-defined object returned when the label is picked.Source: Scene/Label.js, line 613
outlineColor :Color
outlineWidth :Number
pixelOffset :Cartesian2
Gets or sets the pixel offset in screen space from the origin of this label. This is commonly used to align multiple labels and billboards at the same position, e.g., an image and text. The screen space origin is the top, left corner of the canvas;
xincreases from left to right, andyincreases from top to bottom.
The label's origin is indicated by the yellow point.default
Source: Scene/Label.js, line 320 -
pixelOffsetScaleByDistance :NearFarScalar
Gets or sets near and far pixel offset scaling properties of a Label based on the Label's distance from the camera. A label's pixel offset will be scaled between the
NearFarScalar#nearValueandNearFarScalar#farValuewhile the camera distance falls within the upper and lower bounds of the specifiedNearFarScalar#nearandNearFarScalar#far. Outside of these ranges the label's pixel offset scaling remains clamped to the nearest bound. If undefined, pixelOffsetScaleByDistance will be disabled.Examples:
// Example 1. // Set a label's pixel offset scale to 0.0 when the // camera is 1500 meters from the label and scale pixel offset to 10.0 pixels // in the y direction the camera distance approaches 8.0e6 meters. text.pixelOffset = new Cesium.Cartesian2(0.0, 1.0); text.pixelOffsetScaleByDistance = new Cesium.NearFarScalar(1.5e2, 0.0, 8.0e6, 10.0);// Example 2. // disable pixel offset by distance text.pixelOffsetScaleByDistance = undefined;Source: Scene/Label.js, line 417 -
position :Cartesian3
Gets or sets the Cartesian position of this label.Source: Scene/Label.js, line 134
scale :Number
Gets or sets the uniform scale that is multiplied with the label's size in pixels. A scale of
1.0does not change the size of the label; a scale greater than1.0enlarges the label; a positive scale less than1.0shrinks the label.
Applying a large scale value may pixelate the label. To make text larger without pixelation, use a larger font size when callingLabel#fontinstead.
From left to right in the above image, the scales are0.5,1.0, and2.0.Source: Scene/Label.js, line 581 -
show :Boolean
Determines if this label will be shown. Use this to hide or show a label, instead of removing it and re-adding it to the collection.Source: Scene/Label.js, line 104
style :LabelStyle
Gets or sets the style of this label.Source: Scene/Label.js, line 286
text :String
Gets or sets the text of this label.Source: Scene/Label.js, line 165
translucencyByDistance :NearFarScalar
Gets or sets near and far translucency properties of a Label based on the Label's distance from the camera. A label's translucency will interpolate between the
NearFarScalar#nearValueandNearFarScalar#farValuewhile the camera distance falls within the upper and lower bounds of the specifiedNearFarScalar#nearandNearFarScalar#far. Outside of these ranges the label's translucency remains clamped to the nearest bound. If undefined, translucencyByDistance will be disabled.Examples:
// Example 1. // Set a label's translucencyByDistance to 1.0 when the // camera is 1500 meters from the label and disappear as // the camera distance approaches 8.0e6 meters. text.translucencyByDistance = new Cesium.NearFarScalar(1.5e2, 1.0, 8.0e6, 0.0);// Example 2. // disable translucency by distance text.translucencyByDistance = undefined;Source: Scene/Label.js, line 368 -
verticalOrigin :VerticalOrigin
// Use a top, right origin l.horizontalOrigin = Cesium.HorizontalOrigin.RIGHT; l.verticalOrigin = Cesium.VerticalOrigin.TOP;Source: Scene/Label.js, line 537
computeScreenSpacePosition(scene) → Cartesian2
Computes the screen-space position of the label's origin, taking into account eye and pixel offsets. The screen space origin is the top, left corner of the canvas;
xincreases from left to right, andyincreases from top to bottom.Name Type Description sceneScene The scene the label is in. Returns:
The screen-space position of the label.Example:
console.log(l.computeScreenSpacePosition(scene).toString());See:
Source: Scene/Label.js, line 647 -
equals(other) → Boolean
Name Type Description otherLabel The label to compare for equality. Returns:
trueif the labels are equal; otherwise,false.Source: Scene/Label.js, line 670 -
isDestroyed() → Boolean
If this object was destroyed, it should not be used; calling any function other thanisDestroyedwill result in aDeveloperErrorexception.Returns:
True if this object was destroyed; otherwise, false.Source: Scene/Label.js, line 698
