Label
new Cesium.Label()
Throws:
Demo:
staticCesium.Label.enableRightToLeftDetection : Boolean
Default Value: false
Examples:
// Example 1.
  label: {
// Example 2.
  label: {
    text: 'English text'
backgroundColor : Color
Default Value: new Color(0.165, 0.165, 0.165, 0.8)
Gets or sets the background padding, in pixels, of this label. The x value controls horizontal padding, and the y value controls vertical padding.
Default Value: new Cartesian2(7, 5)
disableDepthTestDistance : Number
Gets or sets the distance from the camera at which to disable the depth test to, for example, prevent clipping against terrain. When set to zero, the depth test is always applied. When set to Number.POSITIVE_INFINITY, the depth test is never applied.
Default Value: 0.0
Default Value: undefined
Default Value: Color.WHITE
font : String
Default Value: '30px sans-serif'
Default Value: HorizontalOrigin.LEFT
// Use a top, right origin
outlineColor : Color
Default Value: Color.BLACK
outlineWidth : Number
Default Value: 1.0
default
Default Value: Cartesian2.ZERO
Examples:
// Example 1.
// Example 2.
scale : Number
Default Value: 1.0
Gets or sets near and far scaling properties of a Label based on the label's distance from the camera. A label's scale will interpolate between the NearFarScalar#nearValue and NearFarScalar#farValue while the camera distance falls within the upper and lower bounds of the specified NearFarScalar#near and NearFarScalar#far. Outside of these ranges the label's scale remains clamped to the nearest bound. If undefined, scaleByDistance will be disabled.
Examples:
// Example 1.
// Example 2.
show : Boolean
Default Value: true
showBackground : Boolean
Default Value: LabelStyle.FILL
text : String
Examples:
// Example 1.
// Example 2.
Default Value: VerticalOrigin.BASELINE
equals(other) → Boolean
isDestroyed() → Boolean
