Label
new Cesium.Label()
Throws:
Demo:
backgroundColor : Color
Default Value: new Color(0.165, 0.165, 0.165, 0.8)
Gets or sets the background padding, in pixels, of this label. The x value controls horizontal padding, and the y value controls vertical padding.
Default Value: new Cartesian2(7, 5)
Default Value: undefined
Default Value: Color.WHITE
font : String
Default Value: '30px sans-serif'
Default Value: HorizontalOrigin.LEFT
// Use a top, right origin
outlineColor : Color
Default Value: Color.BLACK
outlineWidth : Number
Default Value: 1.0
default
Default Value: Cartesian2.ZERO
Examples:
// Example 1.
// Example 2.
scale : Number
Default Value: 1.0
Gets or sets near and far scaling properties of a Label based on the label's distance from the camera. A label's scale will interpolate between the NearFarScalar#nearValue and NearFarScalar#farValue while the camera distance falls within the upper and lower bounds of the specified NearFarScalar#near and NearFarScalar#far. Outside of these ranges the label's scale remains clamped to the nearest bound. If undefined, scaleByDistance will be disabled.
Examples:
// Example 1.
// Example 2.
show : Boolean
Default Value: true
showBackground : Boolean
Default Value: false
Default Value: LabelStyle.FILL
text : String
Examples:
// Example 1.
// Example 2.
Default Value: VerticalOrigin.BASELINE
equals(other) → Boolean
isDestroyed() → Boolean
