Label
new Cesium.Label()
Throws:
Demo:
Default Value: undefined
font : String
// Use a top, right origin
outlineColor : Color
outlineWidth : Number
default
Examples:
// Example 1.
// Example 2.
scale : Number
show : Boolean
text : String
Examples:
// Example 1.
// Example 2.
equals(other) → Boolean
isDestroyed() → Boolean
