Label
internal constructor new Cesium.Label(options, labelCollection)
Create labels by calling LabelCollection#add. Do not call the constructor directly.
options Label.ConstructorOptions Object describing initialization options
labelCollection LabelCollection Instance of LabelCollection
Throws:
Demo:
static Cesium.Label.enableRightToLeftDetection : boolean
Default Value: false
Examples:
// Example 1.
const myLabelEntity = viewer.entities.add({
  label: {
// Example 2.
  label: {
    text: 'English text'
Default Value: new Color(0.165, 0.165, 0.165, 0.8)
Gets or sets the background padding, in pixels, of this label. The x value controls horizontal padding, and the y value controls vertical padding.
Default Value: new Cartesian2(7, 5)
disableDepthTestDistance : number
Gets or sets the distance from the camera at which to disable the depth test to, for example, prevent clipping against terrain. When set to zero, the depth test is always applied. When set to Number.POSITIVE_INFINITY, the depth test is never applied.
Default Value: undefined
Default Value: Color.WHITE
Default Value: '30px sans-serif'
Default Value: HorizontalOrigin.LEFT
// Use a top, right origin
Default Value: Color.BLACK
outlineWidth : number
Default Value: 1.0
default
Default Value: Cartesian2.ZERO
Gets or sets near and far pixel offset scaling properties of a Label based on the Label's distance from the camera. A label's pixel offset will be scaled between the NearFarScalar#nearValue and NearFarScalar#farValue while the camera distance falls within the lower and upper bounds of the specified NearFarScalar#near and NearFarScalar#far. Outside of these ranges the label's pixel offset scaling remains clamped to the nearest bound. If undefined, pixelOffsetScaleByDistance will be disabled.
Examples:
// Example 1.
// Example 2.
Default Value: 1.0
Gets or sets near and far scaling properties of a Label based on the label's distance from the camera. A label's scale will interpolate between the NearFarScalar#nearValue and NearFarScalar#farValue while the camera distance falls within the lower and upper bounds of the specified NearFarScalar#near and NearFarScalar#far. Outside of these ranges the label's scale remains clamped to the nearest bound. If undefined, scaleByDistance will be disabled.
Examples:
// Example 1.
// Example 2.
Default Value: true
showBackground : boolean
Default Value: LabelStyle.FILL
totalScale : number
Gets the total scale of the label, which is the label's scale multiplied by the computed relative size of the desired font compared to the generated glyph size.
Default Value: 1.0
Gets or sets near and far translucency properties of a Label based on the Label's distance from the camera. A label's translucency will interpolate between the NearFarScalar#nearValue and NearFarScalar#farValue while the camera distance falls within the lower and upper bounds of the specified NearFarScalar#near and NearFarScalar#far. Outside of these ranges the label's translucency remains clamped to the nearest bound. If undefined, translucencyByDistance will be disabled.
Examples:
// Example 1.
// Example 2.
Default Value: VerticalOrigin.BASELINE
equals(other) → boolean
other Label optional The label to compare for equality.
isDestroyed() → boolean
Type Definitions
Cesium.Label.ConstructorOptions
Initialization options for the Label constructor
Properties:
position Cartesian3 The cartesian position of the label.
id * <optional>
A user-defined object to return when the label is picked with Scene#pick.
show boolean <optional>
true Determines if this label will be shown.
text string <optional>
A string specifying the text of the label.
font string <optional>
'30px sans-serif' A string specifying the font used to draw this label. Fonts are specified using the same syntax as the CSS 'font' property.
style LabelStyle <optional>
LabelStyle.FILL A LabelStyle specifying the style of the label.
scale number <optional>
1.0 A number specifying the uniform scale that is multiplied with the label size.
showBackground boolean <optional>
false Determines if a background behind this label will be shown.
backgroundColor Color <optional>
new Color(0.165, 0.165, 0.165, 0.8) A Color specifying the background color of the label.
backgroundPadding Cartesian2 <optional>
new Cartesian2(7, 5) A Cartesian2 Specifying the horizontal and vertical background padding in pixels.
pixelOffset Cartesian2 <optional>
Cartesian2.ZERO A Cartesian2 specifying the pixel offset in screen space from the origin of this label.
eyeOffset Cartesian3 <optional>
Cartesian3.ZERO A Cartesian3 specifying the 3D Cartesian offset applied to this label in eye coordinates.
horizontalOrigin HorizontalOrigin <optional>
HorizontalOrigin.LEFT A HorizontalOrigin specifying the horizontal origin of this label.
verticalOrigin VerticalOrigin <optional>
VerticalOrigin.BASELINE A VerticalOrigin specifying the vertical origin of this label.
heightReference HeightReference <optional>
HeightReference.NONE A HeightReference specifying the height reference of this label.
fillColor Color <optional>
Color.WHITE A Color specifying the fill color of the label.
outlineColor Color <optional>
Color.BLACK A Color specifying the outline color of the label.
outlineWidth number <optional>
1.0 A number specifying the outline width of the label.
translucencyByDistance NearFarScalar <optional>
A NearFarScalar specifying near and far translucency properties of the label based on the label's distance from the camera.
pixelOffsetScaleByDistance NearFarScalar <optional>
A NearFarScalar specifying near and far pixel offset scaling properties of the label based on the label's distance from the camera.
scaleByDistance NearFarScalar <optional>
A NearFarScalar specifying near and far scaling properties of the label based on the label's distance from the camera.
distanceDisplayCondition DistanceDisplayCondition <optional>
A DistanceDisplayCondition specifying at what distance from the camera that this label will be displayed.
disableDepthTestDistance number <optional>
A number specifying the distance from the camera at which to disable the depth test to, for example, prevent clipping against terrain.
