Label
new Label()
Throws:
Demo:
eyeOffset :Cartesian3
fillColor :Color
font :String
heightReference :HeightReference
horizontalOrigin :HorizontalOrigin
// Use a top, right origin
outlineColor :Color
outlineWidth :Number
pixelOffset :Cartesian2
default
pixelOffsetScaleByDistance :NearFarScalar
Examples:
// Example 1.
// Example 2.
position :Cartesian3
scale :Number
show :Boolean
style :LabelStyle
text :String
translucencyByDistance :NearFarScalar
Examples:
// Example 1.
// Example 2.
verticalOrigin :VerticalOrigin
equals(other) → Boolean
isDestroyed() → Boolean
