Cesium for Unreal 2.12.0
Developing UObjects
It can be a challenge to develop a UObject-derived class that can be used from C++, from Blueprints, and in the Editor while ensuring internal states stay consistent. Here are some tips:
UPROPERTY
  • Add VisibleAnywhere or EditAnywhere depending on whether the property is read-only or editable in the Details panel in the Editor. Or omit both of these if it should not show up in the Editor at all.
  • Add BlueprintReadOnly or BlueprintReadWrite depending on whether the property is read-only or editable from Blueprints. Or omit both of these if it should now be accessible from Blueprints at all.
  • Override the PostEditChangeProperty method to be notified of changes to UPROPERTY values in the Editor.
  • Add a BlueprintSetter attribute to each property to be notified of changes to UPROPERTY values from Blueprints.
  • In almost all cases, UPROPERTY declarations should appear in the private: section of the class and have Meta = (AllowPrivateAccess). This prevents them from being get/set directly from C++ code outside the class, which is important because there is no mechanism like PostEditChangeProperty or BlueprintSetter available from C++ code.
  • In the rare case that no action is necessary when setting a property from C++ (and it's unlikely to be needed in the future), the property can be in the public: section. Such a property probably doesn't need a PostEditChangeProperty or BlueprintSetter either.
  • The function given to BlueprintSetter must be a UFUNCTION. This function should usually be public and it should be the mechanism for setting the property from C++, too. A corresponding BlueprintGetter is usually needed for use by C++ even though it's often not needed for Blueprints.
