cesium-native 0.62.0
CesiumGltf::TypeToPropertyType< uint32_t > Struct Reference
static constexpr PropertyComponentType component
 The PropertyComponentType corresponding to a uint32_t.
static constexpr PropertyType value = PropertyType::Scalar
 The PropertyType corresponding to a uint32_t.
Definition at line 254 of file PropertyTypeTraits.h.
◆ component
PropertyComponentType CesiumGltf::TypeToPropertyType< uint32_t >::component
Initial value:
@ Uint32
A property component equivalent to a uint32_t.
Definition at line 256 of file PropertyTypeTraits.h.
◆ value
Definition at line 259 of file PropertyTypeTraits.h.
