cesium-native 0.62.0
CesiumGltf::TypeToPropertyType< glm::mat< 2, 2, T, P > > Struct Template Reference
static constexpr PropertyComponentType component
 The PropertyComponentType corresponding to a glm::mat<2, 2, ...>.
static constexpr PropertyType value = PropertyType::Mat2
 The PropertyType corresponding to a glm::mat<2, 2, ...>.
template<typename T, glm::qualifier P>
struct CesiumGltf::TypeToPropertyType< glm::mat< 2, 2, T, P > >
Definition at line 349 of file PropertyTypeTraits.h.
◆ component
PropertyComponentType CesiumGltf::TypeToPropertyType< glm::mat< 2, 2, T, P > >::component
Initial value:
Definition at line 352 of file PropertyTypeTraits.h.
◆ value
PropertyType CesiumGltf::TypeToPropertyType< glm::mat< 2, 2, T, P > >::value = PropertyType::Mat2
Definition at line 355 of file PropertyTypeTraits.h.
