cesium-native 0.62.0
CesiumGltf::TypeToPropertyType< float > Struct Reference
static constexpr PropertyComponentType component
 The PropertyComponentType corresponding to a float.
static constexpr PropertyType value = PropertyType::Scalar
 The PropertyType corresponding to a float.
Definition at line 290 of file PropertyTypeTraits.h.
◆ component
PropertyComponentType CesiumGltf::TypeToPropertyType< float >::component
Initial value:
@ Float32
A property component equivalent to a float.
Definition at line 292 of file PropertyTypeTraits.h.
◆ value
Definition at line 295 of file PropertyTypeTraits.h.
