cesium-native 0.62.0
CesiumGltf::TypeToPropertyType< bool > Struct Reference
static constexpr PropertyComponentType component
 The PropertyComponentType corresponding to a bool.
static constexpr PropertyType value = PropertyType::Boolean
 The PropertyType corresponding to a bool.
Definition at line 383 of file PropertyTypeTraits.h.
◆ component
PropertyComponentType CesiumGltf::TypeToPropertyType< bool >::component
Initial value:
Definition at line 385 of file PropertyTypeTraits.h.
◆ value
Definition at line 388 of file PropertyTypeTraits.h.
