cesium-native 0.62.0
CesiumGltf::MetadataConversions< std::string, TFrom, std::enable_if_t< IsMetadataVecN< TFrom >::value||IsMetadataMatN< TFrom >::value > > Struct Template Reference
Converts from a glm::vecN or glm::matN to a string. More...
static std::optional< std::string > convert (const TFrom &from)
 Converts a glm::vecN or glm::matN to a std::string. This uses the format that glm::to_string() outputs for vecNs or matNs respectively.
static std::optional< std::string > convert (TFrom)
template<typename TFrom>
struct CesiumGltf::MetadataConversions< std::string, TFrom, std::enable_if_t< IsMetadataVecN< TFrom >::value||IsMetadataMatN< TFrom >::value > >
Definition at line 611 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< std::string > CesiumGltf::MetadataConversions< std::string, TFrom, std::enable_if_t< IsMetadataVecN< TFrom >::value||IsMetadataMatN< TFrom >::value > >::convert ( const TFrom & from)
inlinestatic
fromThe glm::vecN or glm::matN to be converted.
Definition at line 622 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< std::string > CesiumGltf::MetadataConversions< std::string, TFrom, std::enable_if_t< IsMetadataVecN< TFrom >::value||IsMetadataMatN< TFrom >::value > >::convert ( TFrom )
inlinestatic
