cesium-native 0.62.0
CesiumGltf::MetadataConversions< double, std::string_view > Struct Reference
Converts from std::string_view to a double. More...
static std::optional< double > convert (const std::string_view &from)
static std::optional< double > convert (std::string_view)
Definition at line 547 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< double > CesiumGltf::MetadataConversions< double, std::string_view >::convert ( const std::string_view & from)
inlinestatic
Converts a std::string_view to a double. This assumes that the entire std::string_view represents the number, not just a part of it.
This returns std::nullopt if no number is parsed from the string.
fromThe std::string_view to parse from.
Definition at line 556 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< double > CesiumGltf::MetadataConversions< double, std::string_view, void >::convert ( std::string_view )
inlinestatic
