cesium-native 0.62.0
CesiumGltf::MetadataConversions< double, TFrom, std::enable_if_t< CesiumGltf::IsMetadataInteger< TFrom >::value > > Struct Template Reference
Converts from any integer type to a double. More...
static std::optional< double > convert (TFrom from)
 Converts any integer type to a double. The value may lose precision during conversion.
static std::optional< double > convert (TFrom)
template<typename TFrom>
struct CesiumGltf::MetadataConversions< double, TFrom, std::enable_if_t< CesiumGltf::IsMetadataInteger< TFrom >::value > >
Definition at line 483 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< double > CesiumGltf::MetadataConversions< double, TFrom, std::enable_if_t< CesiumGltf::IsMetadataInteger< TFrom >::value > >::convert ( TFrom from)
inlinestatic
fromThe boolean value to be converted.
Definition at line 493 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< double > CesiumGltf::MetadataConversions< double, TFrom, std::enable_if_t< CesiumGltf::IsMetadataInteger< TFrom >::value > >::convert ( TFrom )
inlinestatic
