cesium-native 0.62.0
CesiumGltf::MetadataConversions< bool, TFrom, std::enable_if_t< CesiumGltf::IsMetadataScalar< TFrom >::value > > Struct Template Reference
Converts from a scalar to a bool. More...
static std::optional< bool > convert (TFrom from)
 Converts a scalar to a boolean. Zero is converted to false, while nonzero values are converted to true.
static std::optional< bool > convert (TFrom)
template<typename TFrom>
struct CesiumGltf::MetadataConversions< bool, TFrom, std::enable_if_t< CesiumGltf::IsMetadataScalar< TFrom >::value > >
Definition at line 45 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< bool > CesiumGltf::MetadataConversions< bool, TFrom, std::enable_if_t< CesiumGltf::IsMetadataScalar< TFrom >::value > >::convert ( TFrom from)
inlinestatic
fromThe scalar to convert from.
Definition at line 55 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< bool > CesiumGltf::MetadataConversions< bool, TFrom, std::enable_if_t< CesiumGltf::IsMetadataScalar< TFrom >::value > >::convert ( TFrom )
inlinestatic
