cesium-native 0.62.0
CesiumGltf::MetadataConversions< TTo, std::string, std::enable_if_t< CesiumGltf::IsMetadataInteger< TTo >::value &&std::is_signed_v< TTo > > > Struct Template Reference
Converts from std::string to a signed integer. More...
static std::optional< TTo > convert (const std::string &from)
 Converts the contents of a std::string to a signed integer. This assumes that the entire std::string represents the number, not just a part of it.
static std::optional< TTo > convert (std::string)
template<typename TTo>
struct CesiumGltf::MetadataConversions< TTo, std::string, std::enable_if_t< CesiumGltf::IsMetadataInteger< TTo >::value &&std::is_signed_v< TTo > > >
Definition at line 186 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< TTo > CesiumGltf::MetadataConversions< TTo, std::string, std::enable_if_t< CesiumGltf::IsMetadataInteger< TTo >::value &&std::is_signed_v< TTo > > >::convert ( const std::string & from)
inlinestatic
This returns std::nullopt if no number is parsed from the string.
fromThe std::string to parse from.
Definition at line 200 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< TTo > CesiumGltf::MetadataConversions< TTo, std::string, std::enable_if_t< CesiumGltf::IsMetadataInteger< TTo >::value &&std::is_signed_v< TTo > > >::convert ( std::string )
inlinestatic
