cesium-native 0.62.0
CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataMatN< TTo >::value &&CesiumGltf::IsMetadataScalar< TFrom >::value > > Struct Template Reference
static std::optional< TTo > convert (TFrom from)
static std::optional< TTo > convert (TFrom)
template<typename TTo, typename TFrom>
struct CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataMatN< TTo >::value &&CesiumGltf::IsMetadataScalar< TFrom >::value > >
Converts from a scalar type to a matN.
Definition at line 770 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< TTo > CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataMatN< TTo >::value &&CesiumGltf::IsMetadataScalar< TFrom >::value > >::convert ( TFrom from)
inlinestatic
Converts a scalar to a matN. The returned vector is initialized with the value in all components. The value may lose precision during conversion depending on the type of the scalar and the component type of the matrix.
If the scalar cannot be reasonably converted to the component type of the matN, std::nullopt is returned.
fromThe scalar value to be converted.
Definition at line 787 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< TTo > CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataMatN< TTo >::value &&CesiumGltf::IsMetadataScalar< TFrom >::value > >::convert ( TFrom )
inlinestatic
