cesium-native 0.62.0
CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataMatN< TTo >::value &&CesiumGltf::IsMetadataMatN< TFrom >::value &&!std::is_same_v< TTo, TFrom > > > Struct Template Reference
Converts from a matN type to another matN type. More...
static std::optional< TTo > convert (TFrom from)
 Converts a value of the given matN to another matN type.
static std::optional< TTo > convert (TFrom)
template<typename TTo, typename TFrom>
struct CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataMatN< TTo >::value &&CesiumGltf::IsMetadataMatN< TFrom >::value &&!std::is_same_v< TTo, TFrom > > >
Definition at line 805 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< TTo > CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataMatN< TTo >::value &&CesiumGltf::IsMetadataMatN< TFrom >::value &&!std::is_same_v< TTo, TFrom > > >::convert ( TFrom from)
inlinestatic
Let M be the length of the given matN, and N be the length of the target matN. If M > N, then only the first N components of the first N columns will be used. Otherwise, if M < N, all other elements in the N x N matrix will be initialized to zero.
If any of the relevant components cannot be converted to the target matN component type, std::nullopt is returned.
fromThe matN value to convert from.
Definition at line 825 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< TTo > CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataMatN< TTo >::value &&CesiumGltf::IsMetadataMatN< TFrom >::value &&!std::is_same_v< TTo, TFrom > > >::convert ( TFrom )
inlinestatic
