cesium-native 0.62.0
CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataVecN< TTo >::value &&CesiumGltf::IsMetadataVecN< TFrom >::value &&!std::is_same_v< TTo, TFrom > > > Struct Template Reference
Converts from a vecN type to another vecN type. More...
static std::optional< TTo > convert (TFrom from)
 Converts a value of the given vecN to another vecN type.
static std::optional< TTo > convert (TFrom)
template<typename TTo, typename TFrom>
struct CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataVecN< TTo >::value &&CesiumGltf::IsMetadataVecN< TFrom >::value &&!std::is_same_v< TTo, TFrom > > >
Definition at line 701 of file MetadataConversions.h.
◆ convert() [1/2]
static std::optional< TTo > CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataVecN< TTo >::value &&CesiumGltf::IsMetadataVecN< TFrom >::value &&!std::is_same_v< TTo, TFrom > > >::convert ( TFrom from)
inlinestatic
If the given vector has more components than the target vecN type, then only its first N components will be used, where N is the dimension of the target vecN type. Otherwise, if the target vecN type has more components, its extra components will be initialized to zero.
If any of the relevant components cannot be converted to the target vecN component type, std::nullopt is returned.
fromThe vecN value to convert from.
Definition at line 721 of file MetadataConversions.h.
◆ convert() [2/2]
static std::optional< TTo > CesiumGltf::MetadataConversions< TTo, TFrom, std::enable_if_t< CesiumGltf::IsMetadataVecN< TTo >::value &&CesiumGltf::IsMetadataVecN< TFrom >::value &&!std::is_same_v< TTo, TFrom > > >::convert ( TFrom )
inlinestatic
