cesium-native 0.62.0
Converts from a floating-point type to an integer. More...
| static std::optional< TTo > | convert (TFrom from) |
| Converts a floating-point value to an integer type. This truncates the floating-point value, rounding it towards zero. | |
| static std::optional< TTo > | convert (TFrom) |
Definition at line 156 of file MetadataConversions.h.
inlinestatic |
If the value is outside the range of the integer type, std::nullopt is returned.
| from | The floating-point value to convert from. |
Definition at line 171 of file MetadataConversions.h.
inlinestatic |
